소개
Use this guide to replace the screen of the Canon PowerShot S230. The guide focuses mainly on the removal of screws and display screen. Fairly simple.
부품
No parts specified.
  1. Using a philips head screw remove the screw on the outside casing of the camera. Set these aside you will need them for re-assembly.
    • Using a philips head screw remove the screw on the outside casing of the camera. Set these aside you will need them for re-assembly.
  2. Using a pry tool pry open the outer casing of the camera in order to access the inside components. Set aside you will need this for re-assembly. Using a pry tool pry open the outer casing of the camera in order to access the inside components. Set aside you will need this for re-assembly. Using a pry tool pry open the outer casing of the camera in order to access the inside components. Set aside you will need this for re-assembly.
    • Using a pry tool pry open the outer casing of the camera in order to access the inside components. Set aside you will need this for re-assembly.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Remove the metal shield and screws from the bottom interior of the camera. Remove the metal shield and screws from the bottom interior of the camera.
    • Remove the metal shield and screws from the bottom interior of the camera.
  5. Remove the screws securing the screen.
    • Remove the screws securing the screen.
  6. Remove screws on the copper facing from the front facing part of the camera. Underneath is a connection to the screen; wiggle it to pull it out, it may take some force.
    • Remove screws on the copper facing from the front facing part of the camera. Underneath is a connection to the screen; wiggle it to pull it out, it may take some force.
결론
Will Appleton
회원 가입일: 2016년 05월 31일
101 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 100
