이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide illustrates how to remove the battery casing.
필요한 것
On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
Remove the four 4.75 mm screws that sit at the bottom of the camera.
Locate the ribbon cable connection to the left of the lens on the main circuit board.
Gently flip open the black latch on the connector and detach the ribbon cable.
거의 끝나갑니다!
결론
