이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the 4.75mm screw located in the top right corner of the backside of the camera.
Remove the four 4.75mm screws located on the bottom of the camera.
Remove the two 4.75mm screws located on the right side of the camera.(the side with the USB adaption plug)
Only remove the back case.
The memory card is held in the metal case located to the right of the LCD screen.
Remove the stuck memory card.
If the small plastic piece described in the previous step did not fall out, remove it now. The piece is located in a small gap above the lens and to the left of the flash.
Locate and remove the three 3.45mm screws on the backside of the camera securing the CF card slot.
Do not remove ribbon cable. It is not necessary to remove
Without removing the ribbon cable, gently remove the memory card.
