주요 콘텐츠로 건너뛰기
Canon PowerShot S400 Shutter Button Assembly Replacement
필요한 것
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: 1 단계, 이미지 2개 중 1개 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: 1 단계, 이미지 2개 중 2개
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: 2 단계, 이미지 3개 중 1개 Canon PowerShot S400 Shutter Button Assembly Replacement: 2 단계, 이미지 3개 중 2개 Canon PowerShot S400 Shutter Button Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot S400 Shutter Button Assembly Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot S400 Shutter Button Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
결론
작성자
5다른 기여자 명과 함께
Ross Bryan
회원 가입일: 01/21/11
375 평판
안내서 3개를 작성함
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G19
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 2,846
