이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the 4.75mm screw located in the top right corner of the backside of the camera.
Remove the four # screws located on the bottom of the camera.
Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
Remove the four screws on the left side of the camera.
This will release a small metal plate. Remove this plate.
Using a spudger, carefully pry the shutter button assembly from the camera.
Install the replacement shutter button assembly.
