주요 콘텐츠로 건너뛰기
Canon PowerShot S410 Front Cover Replacement
필요한 것
  1. Canon PowerShot S410 Front Cover Replacement, Battery: 1 단계, 이미지 2개 중 1개 Canon PowerShot S410 Front Cover Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 Front Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 Front Cover Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot S410 Front Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  4. Canon PowerShot S410 Front Cover Replacement, Back Cover: 4 단계, 이미지 1개 중 1개
    • Start by laying the camera flat with the LCD screen facing up.
    • Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
  5. Canon PowerShot S410 Front Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Position the camera with the bottom facing up.
    • Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
    • Repeat to remove the two 2.3mm screws.
  6. Canon PowerShot S410 Front Cover Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot S410 Front Cover Replacement: 6 단계, 이미지 2개 중 2개
    • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
    • Slide the rubber tab to reveal the bottom screw.
    • Using the screwdriver, remove the two 3.7mm screws.
  7. Canon PowerShot S410 Front Cover Replacement: 7 단계, 이미지 1개 중 1개
    • Turn the camera with the back side facing you.
    • Grip the edges of the back plate, and carefully slide it off.
    • If there is any resistance in movement, double check there are no screws left in the chassis.
  8. Canon PowerShot S410 Front Cover Replacement, Front Cover: 8 단계, 이미지 2개 중 1개 Canon PowerShot S410 Front Cover Replacement, Front Cover: 8 단계, 이미지 2개 중 2개
    • Orient the camera as in the picture.
    • Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
    • Remove the two 3.8mm screws near the strap bracket.
    • Remove the small panel covering the mounting bracket.
    • Remove the door covering the memory card.
  9. Canon PowerShot S410 Front Cover Replacement: 9 단계, 이미지 1개 중 1개
    • Rotate the camera so that the bottom side is facing you.
    • Remove the 3.8mm screw below the mounting bracket using the Phillips screwdriver.
  10. Canon PowerShot S410 Front Cover Replacement: 10 단계, 이미지 1개 중 1개
    • Rotate the camera so that the front is facing you.
    • Grasp the sides of the front cover and carefully pull the front panel off of the camera.
결론
작성자
8다른 기여자 명과 함께
Ryan Bolton
회원 가입일: 01/23/11
307 평판
안내서 3개를 작성함
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011 회원
CPSU-MANESS-W11S11G27
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 6
전체 시간: 965
