주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot S410 LCD Screen Replacement
필요한 것
  1. Canon PowerShot S410 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
    댓글 쓰기
  2. Canon PowerShot S410 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the orange lever and the battery will spring out slightly.
    댓글 쓰기
  3. Canon PowerShot S410 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
    댓글 쓰기
  4. Canon PowerShot S410 LCD Screen Replacement, Back Cover: 4 단계, 이미지 1개 중 1개
    • Start by laying the camera flat with the LCD screen facing up.
    • Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
    댓글 쓰기
  5. Canon PowerShot S410 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Position the camera with the bottom facing up.
    • Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
    • Repeat to remove the two 2.3mm screws.
    댓글 쓰기
  6. Canon PowerShot S410 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
    • Slide the rubber tab to reveal the bottom screw.
    • Using the screwdriver, remove the two 3.7mm screws.
    댓글 쓰기
  7. Canon PowerShot S410 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Turn the camera with the back side facing you.
    • Grip the edges of the back plate, and carefully slide it off.
    • If there is any resistance in movement, double check there are no screws left in the chassis.
    댓글 쓰기
  8. Canon PowerShot S410 LCD Screen Replacement, Front Cover: 8 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement, Front Cover: 8 단계, 이미지 2개 중 2개
    • Orient the camera as in the picture.
    • Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
    • Remove the two 3.8mm screws near the strap bracket.
    • Remove the small panel covering the mounting bracket.
    • Remove the door covering the memory card.
    댓글 쓰기
  9. Canon PowerShot S410 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Rotate the camera so that the bottom side is facing you.
    • Remove the 3.8mm screw below the mounting bracket using the Phillips screwdriver.
    댓글 쓰기
  10. Canon PowerShot S410 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Rotate the camera so that the front is facing you.
    • Grasp the sides of the front cover and carefully pull the front panel off of the camera.
    댓글 쓰기
  11. Canon PowerShot S410 LCD Screen Replacement, LCD Screen: 11 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement, LCD Screen: 11 단계, 이미지 2개 중 2개
    • Position the camera so that the motherboard is facing you.
    • A fingernail or spudger can be used to remove the plastic flap covering the motherboard.
    댓글 쓰기
  12. Canon PowerShot S410 LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Turn the camera so that the bottom side is facing you.
    • Remove the 2.1mm screw using the Phillips #0 screwdriver
    • Grab the sides of the bottom panel and lift to expose the ribbon cable.
    댓글 쓰기
  13. Canon PowerShot S410 LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Turn the camera so that the motherboard is facing you.
    • Using your fingernail, open the black clip holding the ribbon cable.
    • Gently pull out the ribbon cable in the direction of the cable using your fingers or tweezers.
    댓글 쓰기
  14. Canon PowerShot S410 LCD Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Turn the camera so that the LCD screen is facing you.
    • Remove the two 2.1mm screws on the aluminum tabs of the LCD screen using a screwdriver.
    댓글 쓰기
  15. Canon PowerShot S410 LCD Screen Replacement: 15 단계, 이미지 2개 중 1개 Canon PowerShot S410 LCD Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Using a pair of tweezers, carefully pull the top ribbon cable out of the slot.
    • Grasp the sides of the LCD screen and lift off of the camera.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
11다른 기여자 명과 함께
kubayubay
회원 가입일: 01/23/11
103 평판
안내서 1개를 작성함
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011 회원
CPSU-MANESS-W11S11G27
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 42
전체 시간: 4,123
