주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Canon PowerShot S50 Front Panel/Battery Door Replacement
필요한 것
  1. Canon PowerShot S50 Front Panel/Battery Door Replacement, Battery: 1 단계, 이미지 1/2 Canon PowerShot S50 Front Panel/Battery Door Replacement, Battery: 1 단계, 이미지 2/2
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Canon PowerShot S50 Front Panel/Battery Door Replacement: 2 단계, 이미지 1/1
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Canon PowerShot S50 Front Panel/Battery Door Replacement: 3 단계, 이미지 1/2 Canon PowerShot S50 Front Panel/Battery Door Replacement: 3 단계, 이미지 2/2
    • Holding the edges, slide out the battery.
  4. Canon PowerShot S50 Front Panel/Battery Door Replacement, Front Panel/Battery Door: 4 단계, 이미지 1/1
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Canon PowerShot S50 Front Panel/Battery Door Replacement: 5 단계, 이미지 1/1
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Canon PowerShot S50 Front Panel/Battery Door Replacement: 6 단계, 이미지 1/1
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Canon PowerShot S50 Front Panel/Battery Door Replacement: 7 단계, 이미지 1/1
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Canon PowerShot S50 Front Panel/Battery Door Replacement: 8 단계, 이미지 1/1
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Canon PowerShot S50 Front Panel/Battery Door Replacement: 9 단계, 이미지 1/1
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Canon PowerShot S50 Front Panel/Battery Door Replacement: 10 단계, 이미지 1/1
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Canon PowerShot S50 Front Panel/Battery Door Replacement: 11 단계, 이미지 1/1
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Canon PowerShot S50 Front Panel/Battery Door Replacement: 12 단계, 이미지 1/1
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Canon PowerShot S50 Front Panel/Battery Door Replacement: 13 단계, 이미지 1/1
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
결론
Karim
회원 가입일: 04/12/12
24 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-34, Maness Spring 2012 Cal Poly, Team 7-34, Maness Spring 2012 회원
CPSU-MANESS-S12S7G34
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,250
