이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The 1.8 inch LCD Screen is the main method of interaction between the user and the camera. If the screen malfunctions, it may be useful to replace it. New screens can be bought here
필요한 것
Place camera LCD side up and press up on the battery door.
Let it swing open until you can see the battery inside.
Look at the camera from the side with the lanyard and 4 screws.
Remove the two 3.4 mm screws on the metallic colored part.
Disconnect the two plastic ribbons on the lower half of the right motherboard.
Using a spudger, gently separate the back panel from the rest of the camera and remove it.
Remove the 2.6mm screw on the bottom of the camera located directly under the LCD screen.
This screw should be holding two pieces of orange film down.
다른 한 분이 해당 안내서를 완성하였습니다.
