소개
Use this guide to remove the motherboard on the right side of the camera.
필요한 것
Place camera LCD side up and press up on the battery door.
Let it swing open until you can see the battery inside.
Look at the camera from the side with the lanyard and 4 screws.
Remove the two 3.4 mm screws on the metallic colored part.
Disconnect the two plastic ribbons on the lower half of the right motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
