주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot S500 LCD Replacement
필요한 것
    1. Canon PowerShot S500 LCD Replacement, Front and Rear Casing : 1 단계, 이미지 2개 중 1개 Canon PowerShot S500 LCD Replacement, Front and Rear Casing : 1 단계, 이미지 2개 중 2개
      • Unscrew five Phillips screws using a #0 Phillips screwdriver.
      • One screw is on upper right corner of the back panel.
      • The other four screws are on the bottom of the camera.
      댓글 쓰기
    2. Canon PowerShot S500 LCD Replacement: 2 단계, 이미지 1개 중 1개
      • Open the memory card cover by moving the slide switch toward the top end of of the camera.
      • Remove the memory card from the slot.
      댓글 쓰기
    3. Canon PowerShot S500 LCD Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the rear cover from the rest of the camera.
      • This may require gentle rocking of the case to free it.
      댓글 쓰기
    4. Canon PowerShot S500 LCD Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot S500 LCD Replacement: 4 단계, 이미지 2개 중 2개
      • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
      댓글 쓰기
    5. Canon PowerShot S500 LCD Replacement: 5 단계, 이미지 1개 중 1개
      • Free the front cover from the rest of the camera.
      • The cover may require gentle rocking to remove.
      댓글 쓰기
    1. Canon PowerShot S500 LCD Replacement, LCD: 6 단계, 이미지 1개 중 1개
      • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
      댓글 쓰기
    2. Canon PowerShot S500 LCD Replacement: 7 단계, 이미지 1개 중 1개
      • Gently separate the top of LCD from the rest of the camera using your thumb.
      • Be careful not pull the LCD too far because of the ribbon cable connection.
      • Place the Spudger in the hole of the electrical ribbon.
      • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
      • The LCD will still be connected to the rest of the camera
      댓글 쓰기
    3. Canon PowerShot S500 LCD Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot S500 LCD Replacement: 8 단계, 이미지 2개 중 2개
      • Unscrew single Phillips screw with a #0 Phillips screwdriver.
      • Free the bottom panel and attached ribbon from the rest of the camera.
      • Be careful not to damage the ribbon.
      댓글 쓰기
    4. Canon PowerShot S500 LCD Replacement: 9 단계, 이미지 1개 중 1개
      • Turn over the camera.
      • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
      • The plastic will still be connected on the left side.
      댓글 쓰기
    5. Canon PowerShot S500 LCD Replacement: 10 단계, 이미지 1개 중 1개
      • Place the Spudger between the orange ribbon and the black ribbon gate.
      • Lift the ribbon gate using the Spudger.
      댓글 쓰기
    6. Canon PowerShot S500 LCD Replacement: 11 단계, 이미지 1개 중 1개
      • Place the Spudger in the corner of the ribbon above the hole.
      • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
      댓글 쓰기
    7. Canon PowerShot S500 LCD Replacement: 12 단계, 이미지 1개 중 1개
      • Free this ribbon and the bottom panel from the rest of the camera.
      댓글 쓰기
    8. Canon PowerShot S500 LCD Replacement: 13 단계, 이미지 1개 중 1개
      • Turn the camera over so you can see the LCD.
      • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
      댓글 쓰기
    9. Canon PowerShot S500 LCD Replacement: 14 단계, 이미지 1개 중 1개
      • Lift the blue ribbon gate using the Spudger.
      댓글 쓰기
    10. Canon PowerShot S500 LCD Replacement: 15 단계, 이미지 1개 중 1개
      • Insert the Spudger into the hole of the ribbon.
      • Move the Spudger away from the gate to fully remove ribbon.
      댓글 쓰기
    11. Canon PowerShot S500 LCD Replacement: 16 단계, 이미지 1개 중 1개
      • Lift the LCD away from the rest of the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Nathan Balcom
회원 가입일: 01/21/10
102 평판
안내서 8개를 작성함
Cal Poly, Team 16-28, Maness Winter 2010 Cal Poly, Team 16-28, Maness Winter 2010 회원
CPSU-MANESS-W10S16G28
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 37
전체 시간: 3,686
