주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot S80 Flash Replacement
필요한 것
  1. Canon PowerShot S80 Flash Replacement, Outer Casing: 1 단계, 이미지 2개 중 1개 Canon PowerShot S80 Flash Replacement, Outer Casing: 1 단계, 이미지 2개 중 2개
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Flash Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot S80 Flash Replacement: 2 단계, 이미지 2개 중 2개
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Flash Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot S80 Flash Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot S80 Flash Replacement: 3 단계, 이미지 3개 중 3개
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Flash Replacement: 4 단계, 이미지 3개 중 1개 Canon PowerShot S80 Flash Replacement: 4 단계, 이미지 3개 중 2개 Canon PowerShot S80 Flash Replacement: 4 단계, 이미지 3개 중 3개
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: 5 단계, 이미지 1개 중 1개
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Flash Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot S80 Flash Replacement: 6 단계, 이미지 2개 중 2개
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Flash Replacement, Flash: 7 단계, 이미지 1개 중 1개
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Canon PowerShot S80 Flash Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot S80 Flash Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. Canon PowerShot S80 Flash Replacement: 9 단계, 이미지 1개 중 1개
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. Canon PowerShot S80 Flash Replacement: 10 단계, 이미지 1개 중 1개
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Canon PowerShot S80 Flash Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Canon PowerShot S80 Flash Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the flash bulb unit upwards from the camera.
  13. Canon PowerShot S80 Flash Replacement: 13 단계, 이미지 2개 중 1개 Canon PowerShot S80 Flash Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the entire three-part flash assembly from the camera.
결론
작성자
7다른 기여자 명과 함께
BrettH
회원 가입일: 10/28/09
219 평판
안내서 5개를 작성함
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 회원
CPSU-MANESS-SU12S19G5
1 회원
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 37
전체 시간: 3,867
