주요 콘텐츠로 건너뛰기
Canon PowerShot S80 Motherboard Replacement
필요한 것
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: 1 단계, 이미지 1/2 Canon PowerShot S80 Motherboard Replacement, Outer Casing: 1 단계, 이미지 2/2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: 2 단계, 이미지 1/2 Canon PowerShot S80 Motherboard Replacement: 2 단계, 이미지 2/2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: 3 단계, 이미지 1/3 Canon PowerShot S80 Motherboard Replacement: 3 단계, 이미지 2/3 Canon PowerShot S80 Motherboard Replacement: 3 단계, 이미지 3/3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: 4 단계, 이미지 1/3 Canon PowerShot S80 Motherboard Replacement: 4 단계, 이미지 2/3 Canon PowerShot S80 Motherboard Replacement: 4 단계, 이미지 3/3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: 5 단계, 이미지 1/1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: 6 단계, 이미지 1/2 Canon PowerShot S80 Motherboard Replacement: 6 단계, 이미지 2/2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: 8 단계, 이미지 1/1
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: 9 단계, 이미지 1/1
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: 10 단계, 이미지 1/3 Canon PowerShot S80 Motherboard Replacement: 10 단계, 이미지 2/3 Canon PowerShot S80 Motherboard Replacement: 10 단계, 이미지 3/3
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: 11 단계, 이미지 1/2 Canon PowerShot S80 Motherboard Replacement: 11 단계, 이미지 2/2
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: 12 단계, 이미지 1/2 Canon PowerShot S80 Motherboard Replacement: 12 단계, 이미지 2/2
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: 13 단계, 이미지 1/2 Canon PowerShot S80 Motherboard Replacement: 13 단계, 이미지 2/2
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: 14 단계, 이미지 1/1
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: 15 단계, 이미지 1/3 Canon PowerShot S80 Motherboard Replacement: 15 단계, 이미지 2/3 Canon PowerShot S80 Motherboard Replacement: 15 단계, 이미지 3/3
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: 16 단계, 이미지 1/1
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: 17 단계, 이미지 1/1
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: 18 단계, 이미지 1/2 Canon PowerShot S80 Motherboard Replacement: 18 단계, 이미지 2/2
    • Use a spudger to gently lift the motherboard from the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
BrettH
회원 가입일: 10/28/09
219 평판
안내서 5개 작성하였습니다
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012 회원
CPSU-MANESS-SU12S19G5
1 회원
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 4,418
