주요 콘텐츠로 건너뛰기
Canon PowerShot SD 600 Battery/SD Card Replacement
  1. Canon PowerShot SD 600 Battery/SD Card Replacement, Battery/SD Card: 1 단계, 이미지 1/1
    • Turn the camera over so that the battery compartment is visible. The compartment should read "Card/Batt. Open".
    • Open the compartment.
    • Lightly push the compartment lid down and outward. The arrow next to "Card/Batt. Open" indicates the direction you should be pushing.
  2. Canon PowerShot SD 600 Battery/SD Card Replacement: 2 단계, 이미지 1/1
    • Once the lid is open, the battery and SD card compartments become visible.
    • Notice the red tab on the right side of the battery.
    • Slide this tab off the battery.
    • The battery is now free to slide out of the compartment.
    • The battery will not pop out of the compartment. The camera needs to be tilted in order to slide the battery out.
  3. Canon PowerShot SD 600 Battery/SD Card Replacement: 3 단계, 이미지 1/1
    • To remove the SD card push it down and it will eject out. (SD card not shown)
    • Be sure the new or recharged battery is facing the correct direction. An arrow on the battery indicates which end should be inserted into the compartment first.
    • If you plan on dissembling the camera further, you should leave the battery and SD card removed. Make sure to close the battery compartment once the battery and the SD card are removed.
결론
Krystal Eades
회원 가입일: 03/11/13
25 평판
안내서 4개 작성하였습니다
Clemson, Team 13-5, Benson Spring 2013 Clemson, Team 13-5, Benson Spring 2013 회원
CLEM-BENSON-S13S13G5
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 21
전체 시간: 859
