주요 콘텐츠로 건너뛰기
Canon PowerShot SD1000 Flash Unit Replacement
필요한 것
  1. Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Flash Unit Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Flash Unit Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Flash Unit Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Flash Unit Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Flash Unit Replacement, Front Case: 6 단계, 이미지 1개 중 1개
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Flash Unit Replacement: 7 단계, 이미지 1개 중 1개
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Flash Unit Replacement, LCD Screen: 8 단계, 이미지 1개 중 1개
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Flash Unit Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot SD1000 Flash Unit Replacement: 9 단계, 이미지 2개 중 2개
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Flash Unit Replacement: 10 단계, 이미지 1개 중 1개
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Flash Unit Replacement: 11 단계, 이미지 2개 중 1개 Canon PowerShot SD1000 Flash Unit Replacement: 11 단계, 이미지 2개 중 2개
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Flash Unit Replacement: 12 단계, 이미지 3개 중 1개 Canon PowerShot SD1000 Flash Unit Replacement: 12 단계, 이미지 3개 중 2개 Canon PowerShot SD1000 Flash Unit Replacement: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: 13 단계, 이미지 2개 중 1개 Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: 13 단계, 이미지 2개 중 2개
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Flash Unit Replacement: 14 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Flash Unit Replacement: 15 단계, 이미지 1개 중 1개
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Flash Unit Replacement: 16 단계, 이미지 2개 중 1개 Canon PowerShot SD1000 Flash Unit Replacement: 16 단계, 이미지 2개 중 2개
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Phillip Phung
회원 가입일: 01/19/12
666 평판
안내서 9개를 작성함
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 회원
CPSU-MANESS-W12S8G18
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 3,769
