주요 콘텐츠로 건너뛰기
Canon PowerShot SD1000 Front Case Replacement
필요한 것
  1. Canon PowerShot SD1000 Front Case Replacement, Back Panel: 1 단계, 이미지 1/2 Canon PowerShot SD1000 Front Case Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Front Case Replacement: 2 단계, 이미지 1/1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Front Case Replacement: 3 단계, 이미지 1/1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Front Case Replacement: 4 단계, 이미지 1/1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Front Case Replacement: 5 단계, 이미지 1/1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Front Case Replacement, Front Case: 6 단계, 이미지 1/1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Front Case Replacement: 7 단계, 이미지 1/1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
결론
Phillip Phung
회원 가입일: 01/19/12
651 평판
안내서 9개 작성하였습니다
Cal Poly, Team 8-18, Maness Winter 2012 Cal Poly, Team 8-18, Maness Winter 2012 회원
CPSU-MANESS-W12S8G18
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 12
전체 시간: 1,342
