주요 콘텐츠로 건너뛰기
Canon PowerShot SD1100 IS Function Buttons Replacement
필요한 것
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: 1 단계, 이미지 2개 중 1개 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: 1 단계, 이미지 2개 중 2개
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: 2 단계, 이미지 3개 중 1개 Canon PowerShot SD1100 IS Function Buttons Replacement: 2 단계, 이미지 3개 중 2개 Canon PowerShot SD1100 IS Function Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot SD1100 IS Function Buttons Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot SD1100 IS Function Buttons Replacement: 3 단계, 이미지 3개 중 3개
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: 5 단계, 이미지 1개 중 1개
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: 9 단계, 이미지 1개 중 1개
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: 10 단계, 이미지 2개 중 1개 Canon PowerShot SD1100 IS Function Buttons Replacement: 10 단계, 이미지 2개 중 2개
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: 11 단계, 이미지 1개 중 1개
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: 12 단계, 이미지 1개 중 1개
    • Congratulations! The function button board can now be replaced.
결론
작성자
4다른 기여자 명과 함께
Wyatt Chan
회원 가입일: 01/05/11
235 평판
안내서 2개를 작성함
Cal Poly, Team 3-32, Regan Winter 2011 Cal Poly, Team 3-32, Regan Winter 2011 회원
CPSU-REGAN-W11S3G32
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 2,094
