주요 콘텐츠로 건너뛰기
Canon PowerShot SD1200 IS Motherboard
필요한 것
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: 1 단계, 이미지 1/1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Motherboard: 2 단계, 이미지 1/3 Canon PowerShot SD1200 IS Motherboard: 2 단계, 이미지 2/3 Canon PowerShot SD1200 IS Motherboard: 2 단계, 이미지 3/3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Motherboard: 3 단계, 이미지 1/2 Canon PowerShot SD1200 IS Motherboard: 3 단계, 이미지 2/2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: 4 단계, 이미지 1/1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
  5. Canon PowerShot SD1200 IS Motherboard: 5 단계, 이미지 1/1
    • Lift off the mechanical shutter button assembly.
  6. Canon PowerShot SD1200 IS Motherboard: 6 단계, 이미지 1/2 Canon PowerShot SD1200 IS Motherboard: 6 단계, 이미지 2/2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
  7. Canon PowerShot SD1200 IS Motherboard: 7 단계, 이미지 1/1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
  8. Canon PowerShot SD1200 IS Motherboard: 8 단계, 이미지 1/1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
  9. Canon PowerShot SD1200 IS Motherboard: 9 단계, 이미지 1/1
    • Lift out the motherboard.
결론
Jeff Casper
회원 가입일: 09/15/16
848 평판
안내서 7개 작성하였습니다
USF Tampa, Team 17-5, Blackwell Fall 2016 USF Tampa, Team 17-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 394
