주요 콘텐츠로 건너뛰기
Canon PowerShot SD1300 IS Flash Assembly Replacement
필요한 것
  1. Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 1/3 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 2/3 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 3/3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
  2. Canon PowerShot SD1300 IS Flash Assembly Replacement: 2 단계, 이미지 1/1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Flash Assembly Replacement: 3 단계, 이미지 1/1
    • Remove a 3mm J00 screw from behind wires under the flash.
  4. Canon PowerShot SD1300 IS Flash Assembly Replacement: 4 단계, 이미지 1/1
    • Use plastic opening tool to remove the screen to gain access to the screws to remove the Flash Assembly.
  5. Canon PowerShot SD1300 IS Flash Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the two 3mm J00 screws under the screen.
    • Remove the 4mm J00 screws under the screen.
    • The flash assembly is now released and should be able to be removed from the front side of the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Clayton
회원 가입일: 03/20/17
560 평판
안내서 5개 작성하였습니다
Texas Tech, Team S13-G1, Bennett Spring 2017 Texas Tech, Team S13-G1, Bennett Spring 2017 회원
TTU-BENNETT-S17S13G1
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 264
