주요 콘텐츠로 건너뛰기
Canon PowerShot SD1300 IS Lens Replacement
필요한 것
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: 1 단계, 이미지 1/3 Canon PowerShot SD1300 IS Lens Replacement, Lens: 1 단계, 이미지 2/3 Canon PowerShot SD1300 IS Lens Replacement, Lens: 1 단계, 이미지 3/3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
  2. Canon PowerShot SD1300 IS Lens Replacement: 2 단계, 이미지 1/1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Lens Replacement: 3 단계, 이미지 1/1
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
  4. Canon PowerShot SD1300 IS Lens Replacement: 4 단계, 이미지 1/1
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Clayton
회원 가입일: 03/20/17
560 평판
안내서 5개 작성하였습니다
Texas Tech, Team S13-G1, Bennett Spring 2017 Texas Tech, Team S13-G1, Bennett Spring 2017 회원
TTU-BENNETT-S17S13G1
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 49
전체 시간: 1,266
