주요 콘텐츠로 건너뛰기
Canon PowerShot SD1400 IS Image Capture Button Replacement
Braxton Beal
Braxton Beal5 다른 기여자
최종 수정일 October 15, 2018
30 - 35 분
조정
The image capture button can break or become stuck. This guide details how to replace the image capture button and the surrounding plastic housing on the Canon PowerShot SD1400 IS camera.
필요한 것
도구
더보기...
  1. Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: 1 단계, 이미지 2개 중 1개 Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #00 driver to remove the four 2.0 mm Phillips screws on the camera housing.
    • There are two screws on either side.
  2. Canon PowerShot SD1400 IS Image Capture Button Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #1 driver to remove the one 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS Image Capture Button Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the face housing from the body of the camera.
  4. Canon PowerShot SD1400 IS Image Capture Button Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the camera over and remove the rear housing.
  5. Canon PowerShot SD1400 IS Image Capture Button Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the button panel if it did not fall out on its own.
  6. Canon PowerShot SD1400 IS Image Capture Button Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips copper screw from the top of the camera.
    • This screw is only visible after the front and rear panels have been removed.
  7. Canon PowerShot SD1400 IS Image Capture Button Replacement: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips silver screw from the rear face of the camera.
  8. Canon PowerShot SD1400 IS Image Capture Button Replacement: 8 단계, 이미지 1개 중 1개
    • Use a plastic spudger to lift the golden film off of the microchip on the front face of the camera, exposing a screw.
  9. Canon PowerShot SD1400 IS Image Capture Button Replacement: 9 단계, 이미지 1개 중 1개
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips screw.
  10. Canon PowerShot SD1400 IS Image Capture Button Replacement: 10 단계, 이미지 2개 중 1개 Canon PowerShot SD1400 IS Image Capture Button Replacement: 10 단계, 이미지 2개 중 2개
    • Use a metal spudger to carefully pry the small black tab away from the connector that secures one end of the golden film.
    • When fully released, the small black tab will stand up straight from the face of the camera and the golden film will no longer be secured.
  11. Canon PowerShot SD1400 IS Image Capture Button Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully insert a metal spudger under the two clusters of wires that are plugged into the small chip on the face of the camera.
    • One cluster of wires is red, the other cluster is black.
    • Pull the wires parallel to the face of the camera to disconnect them from the small chip.
  12. Canon PowerShot SD1400 IS Image Capture Button Replacement: 12 단계, 이미지 1개 중 1개
    • The image capture button housing can now be removed from the body of the camera and replaced.
결론
Follow these instructions in reverse order to reassemble the device.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Braxton Beal
회원 가입일: 01/30/18
702 평판
안내서 3개를 작성함
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G3
3 회원들
안내서 4개를 작성함
댓글 한 개
Where can do you buy replacement parts?
Chase Mahard - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 307
