주요 콘텐츠로 건너뛰기
Canon PowerShot SD1400 IS USB Port Replacement
필요한 것
  1. Canon PowerShot SD1400 IS USB Port Replacement, USB Port: 1 단계, 이미지 3개 중 1개 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: 1 단계, 이미지 3개 중 2개 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: 1 단계, 이미지 3개 중 3개
    • Remove the four 2mm Phillips #00 screws on both sides of the camera.
  2. Canon PowerShot SD1400 IS USB Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the single 4mm Phillips #00 screw from the bottom.
  3. Canon PowerShot SD1400 IS USB Port Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the front face panel off of the camera.
  4. Canon PowerShot SD1400 IS USB Port Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the rear panel of the camera.
    • The user interface panel, side and bottom panel of the camera may fall down by itself while you are taking the rear panel of the camera.
  5. Canon PowerShot SD1400 IS USB Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 3mm Phillips #000 screw from the top of the camera.
  6. Canon PowerShot SD1400 IS USB Port Replacement: 6 단계, 이미지 1개 중 1개
    • Pry the golden ribbon cable from the motherboard with a plastic opening tool.
    • A screw will be visible underneath the golden ribbon after prying it.
  7. Canon PowerShot SD1400 IS USB Port Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 3mm Phillips #000 screw from the motherboard.
  8. Canon PowerShot SD1400 IS USB Port Replacement: 8 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
  9. Canon PowerShot SD1400 IS USB Port Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot SD1400 IS USB Port Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Unplug the small chip from the face of the camera using a pair of tweezers.
  10. Canon PowerShot SD1400 IS USB Port Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the 3mm Phillips #000 screw from the rear face of the camera.
  11. Canon PowerShot SD1400 IS USB Port Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the top panel from the camera.
  12. Canon PowerShot SD1400 IS USB Port Replacement: 12 단계, 이미지 1개 중 1개
    • Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
  13. Canon PowerShot SD1400 IS USB Port Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the 3mm Phillips #000 screw located at the top right of the USB port.
  14. Canon PowerShot SD1400 IS USB Port Replacement: 14 단계, 이미지 2개 중 1개 Canon PowerShot SD1400 IS USB Port Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the USB port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Faris Rezwan
회원 가입일: 05/21/18
457 평판
안내서 2개를 작성함
IUPUI, Team S1-G2, Harley Spring 2018 IUPUI, Team S1-G2, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G2
7 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 321
