이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use your fingernail to slide the dark gray tab located on the bottom of the device towards the edge of camera.
Slide the light gray door away from the LCD screen and pull up to open the door.
Rotate the small brown tab towards the edge of the camera.
The battery should pop up.
Close the light gray battery compartment door.
Remove the six 2.8 mm Phillips screws on the outside of the case. Two screws are found on each side of the camera, and the final two are found on the bottom.
Use your fingers to carefully pry off the back casing from the camera assembly.
Push the buttons out with your finger if they did not fall out while removing the casing.
Pull off the white plastic side piece if it did not fall out while removing the casing.
Remove the one 2.2 mm Phillips screw from the bottom of the camera.
Take off the print button.
Use your fingers to carefully pry off the front casing of the camera. The front casing should pull straight off.
Use the flat end of the spudger to lift open the white plastic latch on the front of the camera. Once the latch is lifted up, move the latch up towards the top edge of the camera.
Remove the top button assembly by pulling straight up.
Remove the one 2.4 mm Phillips screw from the bottom of the motherboard.
Remove the two 3.9 mm Phillips screws from the top of the motherboard.
Remove the one 2.4 mm Phillips screw directly above the top right corner of the LCD screen.
Use the flat end of the spudger to lift up the small black connector from the back side of the motherboard. The connector should just lift straight up.
Hold the camera at an angle to locate the small blue ZIF connector on the back side of the motherboard and next to the LCD screen.
Use the flat end of the spudger to flip up the tab of the blue ZIF connector. Slide the ribbon cable out.
Remove the four 2.6 mm Phillips screws located underneath where the LCD screen used to be.
Remove the one 4.2 mm Phillips screw from the bottom of the back face of the camera.
Using the flat end of the spudger, begin to slightly peel back the orange ribbon cable from the rest of the camera by lifting up at the bottom corner. The ribbon cable should pop off of the pegs.
Rotate the speaker so that it unlatches from the camera frame. Then use the flat end of the spudger to lift up the speaker from the rest of the camera.
Use the flat end of the spudger to peel back the orange ribbon cable on the top of the camera where the power button contact is located. Only apply enough force to lift the power button contact up from the rest of the camera.
Use the flat end of the spudger to lift up the LED bulb from the rest of the camera.
Rotate the camera upside down to locate the small black ZIF connector located in the middle of the camera.
Use the flat end of the spudger to flip up the tab on the black ZIF connector. Pull the ribbon cable straight out.
Remove the orange ribbon cable from the rest of the camera.
Remove the one 4.3 mm Phillips screw that is now visible, which is located at the top right of the back of the camera.
Locate the two ZIF connectors on the front of the camera.
Use the flat end of the spudger to flip up the tab on the blue ZIF connector. Then pull the ribbon cable straight out.
Lay the camera on its front side.
Hold down on the camera's metal casing with one hand. Using your other hand, lift the LCD screen straight up, making sure the LCD screen's ribbon cable slides free of metal casing.
Use your fingers to carefully pry off the back metal casing.
Separate the metal case and tripod internal thread end from the rest of the camera.
Use your fingers to give a small gap of space between the bottom of the lens assembly and the motherboard.
Slide the small circular battery, which is part of the flash assembly, through the small gap.
Separate the flash assembly from the rest of the camera.
