주요 콘텐츠로 건너뛰기
Canon PowerShot SD30 Control Panel Replacement
필요한 것
  1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Canon PowerShot SD30 Control Panel Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Control Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Control Panel Replacement, Back Cover: 3 단계, 이미지 3개 중 1개 Canon PowerShot SD30 Control Panel Replacement, Back Cover: 3 단계, 이미지 3개 중 2개 Canon PowerShot SD30 Control Panel Replacement, Back Cover: 3 단계, 이미지 3개 중 3개
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Control Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Control Panel Replacement, Control Panel: 5 단계, 이미지 3개 중 1개 Canon PowerShot SD30 Control Panel Replacement, Control Panel: 5 단계, 이미지 3개 중 2개 Canon PowerShot SD30 Control Panel Replacement, Control Panel: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
    • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
  6. Canon PowerShot SD30 Control Panel Replacement: 6 단계, 이미지 3개 중 1개 Canon PowerShot SD30 Control Panel Replacement: 6 단계, 이미지 3개 중 2개 Canon PowerShot SD30 Control Panel Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the camera over to the side with the lens and remove the ribbon on the left side.
    • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
  7. Canon PowerShot SD30 Control Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up the button that connects to the power button of the camera so you can remove the control panel.
  8. Canon PowerShot SD30 Control Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the control panel from the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Diego Hughes
회원 가입일: 09/21/18
139 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 367
