부품
부품은 필요하지 않습니다.
  1. There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
    • There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
    • Carefully remove the screws using a screwdriver and put them somewhere safe so they will not get lost.
  4. Open the case gently. The wrist strap plate and disk pieces will fall out during the process.  The second picture shows what wrist strap plate and disk looks like (The circled parts). Replace the broken camera case with the new one.
    • Open the case gently. The wrist strap plate and disk pieces will fall out during the process. The second picture shows what wrist strap plate and disk looks like (The circled parts).
    • Replace the broken camera case with the new one.
결론
Yi Huang Ke
회원 가입일: 2011년 10월 18일
51 평판
안내서 4개 작성하였습니다
James Madison, Team 1-1, Allen Fall 2011 James Madison, Team 1-1, Allen Fall 2011 회원
JMU-ALLEN-F11S1G1
4 회원들
안내서 4개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,715
