주요 콘텐츠로 건너뛰기
Canon PowerShot SD400 LCD Replacement
필요한 것
  1. Canon PowerShot SD400 LCD Replacement, Battery: 1 단계, 이미지 2개 중 1개 Canon PowerShot SD400 LCD Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery cover open (indicated by the red box).
  2. Canon PowerShot SD400 LCD Replacement: 2 단계, 이미지 1개 중 1개
    • Push in the orange clip (indicated by the red box) to eject the battery.
  3. Canon PowerShot SD400 LCD Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the charged battery back into the slot (indicated by the red box).
    • Close the cover.
  4. Canon PowerShot SD400 LCD Replacement, LCD: 4 단계, 이미지 3개 중 1개 Canon PowerShot SD400 LCD Replacement, LCD: 4 단계, 이미지 3개 중 2개 Canon PowerShot SD400 LCD Replacement, LCD: 4 단계, 이미지 3개 중 3개
    • Locate these six screws that need to be removed to open the camera’s housing. These screws can be found on the bottom and both sides of the camera.
  5. Canon PowerShot SD400 LCD Replacement: 5 단계, 이미지 3개 중 1개 Canon PowerShot SD400 LCD Replacement: 5 단계, 이미지 3개 중 2개 Canon PowerShot SD400 LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Using the screwdriver, carefully remove the exterior screws and place them in a safe location to avoid misplacing them.
  6. Canon PowerShot SD400 LCD Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot SD400 LCD Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the interior screw that is above the top right of the LCD screen.
    • Remove the screw using the screwdriver.
  7. Canon PowerShot SD400 LCD Replacement: 7 단계, 이미지 3개 중 1개 Canon PowerShot SD400 LCD Replacement: 7 단계, 이미지 3개 중 2개 Canon PowerShot SD400 LCD Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the two clips on the left side of the LCD screen.
    • Carefully insert the tip of a flat-head screwdriver under the two clips of the LCD screen.
    • Slowly lift the screen using the flat-head screwdriver.
    • Potential for device damage Lift the screen gently to avoid any damage.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Yi Huang Ke
회원 가입일: 10/18/11
51 평판
안내서 4개를 작성함
James Madison, Team 1-1, Allen Fall 2011 James Madison, Team 1-1, Allen Fall 2011 회원
JMU-ALLEN-F11S1G1
4 회원들
안내서 4개를 작성함
1가이드 댓글
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 3,625
