주요 콘텐츠로 건너뛰기
Canon PowerShot SD450 LCD Screen Replacement
필요한 것
  1. Canon PowerShot SD450 LCD Screen Replacement, Casing: 1 단계, 이미지 1개 중 1개
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SD450 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
  7. Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 Canon PowerShot SD450 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
    • Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
  8. Canon PowerShot SD450 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the tripod mount screw.
    • Turn the camera around so that the screen is facing you, and the camera is upright.
  9. Canon PowerShot SD450 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the screw at the top right of the screen.
  10. Canon PowerShot SD450 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Lift up the screen to reveal the tripod mount screw.
  11. Canon PowerShot SD450 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
  12. Canon PowerShot SD450 LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Pierre Teplitxky
회원 가입일: 04/10/10
152 평판
안내서 2개를 작성함
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G85
4 회원들
안내서 5개를 작성함
3가이드 댓글
Followed the steps and replaced the broken screen. Now I get only a white screen when turning the camera on. It does take pictures but it won't show anything but a little red dotted arrow on the right hand side over the white screen. Do you have a clue of what is happening?
Roberto - 답글
Salve, dove posso acquistare un display?
Germano Tinari - 답글
Salve, sapreste dirmi dove posso acquistare un display?
Germano Tinari - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 6,982
