주요 콘텐츠로 건너뛰기
Canon PowerShot SD450 Outer Case replacement
필요한 것
  1. Canon PowerShot SD450 Outer Case replacement, Casing: 1 단계, 이미지 1/1
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Canon PowerShot SD450 Outer Case replacement: 2 단계, 이미지 1/1
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Canon PowerShot SD450 Outer Case replacement: 3 단계, 이미지 1/2 Canon PowerShot SD450 Outer Case replacement: 3 단계, 이미지 2/2
    • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  4. Canon PowerShot SD450 Outer Case replacement: 4 단계, 이미지 1/1
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  5. Canon PowerShot SD450 Outer Case replacement: 5 단계, 이미지 1/1
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  6. Canon PowerShot SD450 Outer Case replacement: 6 단계, 이미지 1/1
    • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
    • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Curtis Wagner
회원 가입일: 04/10/10
32 평판
안내서 1개 작성함
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G85
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 3,569
