주요 콘텐츠로 건너뛰기
Canon PowerShot SD500 Digital ELPH LCD Replacement
필요한 것
  1. Canon PowerShot SD500 Digital ELPH LCD Replacement, Battery: 1 단계, 이미지 1/1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH LCD Replacement: 2 단계, 이미지 1/2 Canon PowerShot SD500 Digital ELPH LCD Replacement: 2 단계, 이미지 2/2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: 3 단계, 이미지 1/2 Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: 3 단계, 이미지 2/2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH LCD Replacement: 4 단계, 이미지 1/1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH LCD Replacement: 5 단계, 이미지 1/1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH LCD Replacement: 6 단계, 이미지 1/1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH LCD Replacement: 7 단계, 이미지 1/1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH LCD Replacement: 8 단계, 이미지 1/1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH LCD Replacement: 9 단계, 이미지 1/2 Canon PowerShot SD500 Digital ELPH LCD Replacement: 9 단계, 이미지 2/2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH LCD Replacement, Button Contact Panel: 10 단계, 이미지 1/1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH LCD Replacement: 11 단계, 이미지 1/1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH LCD Replacement: 12 단계, 이미지 1/3 Canon PowerShot SD500 Digital ELPH LCD Replacement: 12 단계, 이미지 2/3 Canon PowerShot SD500 Digital ELPH LCD Replacement: 12 단계, 이미지 3/3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH LCD Replacement, LCD: 13 단계, 이미지 1/1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH LCD Replacement: 14 단계, 이미지 1/1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH LCD Replacement: 15 단계, 이미지 1/2 Canon PowerShot SD500 Digital ELPH LCD Replacement: 15 단계, 이미지 2/2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Taylor Shields
회원 가입일: 10/13/14
846 평판
안내서 8개 작성하였습니다
Clemson, Team 2-1, Benson Fall 2014 Clemson, Team 2-1, Benson Fall 2014 회원
CLEM-BENSON-F14S2G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 588
