소개
The lens is the device that focuses the image seen by a camera. Because it is the only moving part, it can easily malfunction, causing blurry pictures or even a camera error.
필요한 것
Slide open the battery cover.
Push the small orange tab to the side so the battery can be removed.
Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
Carefully wedge the pry tool under the ribbon in the ribbon gate.
Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
Arrange camera so it is facing up towards you.
Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
Unscrew three .12 inch long Phillips screws using a #00 Phillips screwdriver from the back of the camera.
