주요 콘텐츠로 건너뛰기
Canon PowerShot SD700 LCD screen Replacement
필요한 것
  1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: 1 단계, 이미지 1개 중 1개
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 LCD screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 LCD screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 LCD screen Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 LCD screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 LCD screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 LCD screen Replacement, LCD screen: 7 단계, 이미지 1개 중 1개
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 LCD screen Replacement: 8 단계, 이미지 3개 중 1개 Canon PowerShot SD700 LCD screen Replacement: 8 단계, 이미지 3개 중 2개 Canon PowerShot SD700 LCD screen Replacement: 8 단계, 이미지 3개 중 3개
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 LCD screen Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Emilio Rossi
회원 가입일: 04/07/11
113 평판
안내서 3개를 작성함
Cal Poly, Team 9-71, Walters Spring 2011 Cal Poly, Team 9-71, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G71
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 2,840
