소개
Follow these steps to remove and install a new LCD screen.
필요한 것
Remove the two screws that connect the LCD and backlight to the main body of the camera.
Carefully lift the ZIF connector that covers the thick ribbon cable.
This ZIF connector is fragile. Use caution when lifting it from its down position.
Insert the new LCD and reassemble the camera.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
