주요 콘텐츠로 건너뛰기
Canon PowerShot SD780 IS LCD Screen Replacement
필요한 것
  1. Canon PowerShot SD780 IS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Turn the camera off by pressing the power button.
    • Also, make sure the battery is removed, as to avoid any shock injuries. To remove the battery located at the bottom corner of the camera, slide the panel towards the corner. Push the orange tab upwards and remove the battery.
  2. Canon PowerShot SD780 IS LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot SD780 IS LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove five screws from the camera casing using a Phillips #00 screwdriver.
    • There are two 2 mm screws located on the left side of the camera.
  3. Canon PowerShot SD780 IS LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the front panel of the camera case to expose the top left copper strip.
    • Gently pull the copper strip upward and disconnect it from the camera.
  4. Canon PowerShot SD780 IS LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screw on the far left-hand side of the front of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot SD780 IS LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully pull the case apart at the seam. The case will detach from the camera in two pieces.
  6. Canon PowerShot SD780 IS LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the indicated "L" shaped bracket from around the bottom and right side of the LCD screen.
  7. Canon PowerShot SD780 IS LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Insert the flat side of your spudger tool carefully into the top of the LCD screen and lift the screen free.
    • Set the broken screen aside and place the new screen on top of the LCD screen.
결론
작성자
12다른 기여자 명과 함께
Arlene Ale
회원 가입일: 03/13/14
455 평판
안내서 4개를 작성함
New Mexico State, Team 1-5, Easley Spring 2014 New Mexico State, Team 1-5, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G5
2 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 20
전체 시간: 1,351
