주요 콘텐츠로 건너뛰기
Canon PowerShot SD800 IS LCD Assembly Replacement
필요한 것
  1. Canon PowerShot SD800 IS LCD Assembly Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove one 2.25mm screw on the bottom.
  2. Canon PowerShot SD800 IS LCD Assembly Replacement: 2 단계, 이미지 1/1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Canon PowerShot SD800 IS LCD Assembly Replacement: 3 단계, 이미지 1/1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Canon PowerShot SD800 IS LCD Assembly Replacement: 4 단계, 이미지 1/1
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Canon PowerShot SD800 IS LCD Assembly Replacement, LCD Assembly: 5 단계, 이미지 1/1
    • Remove 2 2.4mm screws on bottom.
  6. Canon PowerShot SD800 IS LCD Assembly Replacement: 6 단계, 이미지 1/1
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Canon PowerShot SD800 IS LCD Assembly Replacement: 7 단계, 이미지 1/1
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Canon PowerShot SD800 IS LCD Assembly Replacement: 8 단계, 이미지 1/1
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeremy Rabaino
회원 가입일: 10/10/10
135 평판
안내서 6개 작성하였습니다
Cal Poly, Team 20-9, Maness Fall 2010 Cal Poly, Team 20-9, Maness Fall 2010 회원
CPSU-MANESS-F10S20G9
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
where can I buy a replacement LCD screen for a SD800 IS
ALFRED - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,275
