소개
Use this guide to remove a broken flash unit from your Canon PowerShot SD850 IS.
부품
지정된 부품이 없습니다.
Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
거의 끝나갑니다!
결론
