주요 콘텐츠로 건너뛰기
Canon PowerShot SD850 IS Function Set Button Replacement
필요한 것
  1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: 1 단계, 이미지 3개 중 1개 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: 1 단계, 이미지 3개 중 2개 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Function Set Button Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Function Set Button Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS Function Set Button Replacement, Case: 3 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Function Set Button Replacement, Case: 3 단계, 이미지 2개 중 2개
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS Function Set Button Replacement: 4 단계, 이미지 3개 중 1개 Canon PowerShot SD850 IS Function Set Button Replacement: 4 단계, 이미지 3개 중 2개 Canon PowerShot SD850 IS Function Set Button Replacement: 4 단계, 이미지 3개 중 3개
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS Function Set Button Replacement: 5 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Function Set Button Replacement: 5 단계, 이미지 2개 중 2개
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS Function Set Button Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Function Set Button Replacement: 6 단계, 이미지 2개 중 2개
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS Function Set Button Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS Function Set Button Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: 9 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: 9 단계, 이미지 2개 중 2개
    • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
  10. Canon PowerShot SD850 IS Function Set Button Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the function set button ribbon cable from the two guide pins.
  11. Canon PowerShot SD850 IS Function Set Button Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
결론
작성자
6다른 기여자 명과 함께
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 14
전체 시간: 1,286
