주요 콘텐츠로 건너뛰기
Canon PowerShot SD850 IS LCD Screen Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 1 단계, 이미지 1/3 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 1 단계, 이미지 2/3 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS LCD Screen Replacement: 2 단계, 이미지 1/2 Canon PowerShot SD850 IS LCD Screen Replacement: 2 단계, 이미지 2/2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS LCD Screen Replacement, Case: 3 단계, 이미지 1/2 Canon PowerShot SD850 IS LCD Screen Replacement, Case: 3 단계, 이미지 2/2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS LCD Screen Replacement: 4 단계, 이미지 1/3 Canon PowerShot SD850 IS LCD Screen Replacement: 4 단계, 이미지 2/3 Canon PowerShot SD850 IS LCD Screen Replacement: 4 단계, 이미지 3/3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS LCD Screen Replacement: 5 단계, 이미지 1/2 Canon PowerShot SD850 IS LCD Screen Replacement: 5 단계, 이미지 2/2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS LCD Screen Replacement: 6 단계, 이미지 1/2 Canon PowerShot SD850 IS LCD Screen Replacement: 6 단계, 이미지 2/2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS LCD Screen Replacement: 7 단계, 이미지 1/1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS LCD Screen Replacement: 8 단계, 이미지 1/1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS LCD Screen Replacement, LCD Screen: 9 단계, 이미지 1/2 Canon PowerShot SD850 IS LCD Screen Replacement, LCD Screen: 9 단계, 이미지 2/2
    • Remove the three screws attached to the bottom of the LCD brackets
  10. Canon PowerShot SD850 IS LCD Screen Replacement: 10 단계, 이미지 1/2 Canon PowerShot SD850 IS LCD Screen Replacement: 10 단계, 이미지 2/2
    • Remove the one quarter bracket around the LCD screen
    • Remove the three quarter bracket around the LCD screen.
  11. Canon PowerShot SD850 IS LCD Screen Replacement: 11 단계, 이미지 1/3 Canon PowerShot SD850 IS LCD Screen Replacement: 11 단계, 이미지 2/3 Canon PowerShot SD850 IS LCD Screen Replacement: 11 단계, 이미지 3/3
    • Please Note: There are two areas of interest before removing the final bracket.
    • First, use a spudger to pry the the two tabs from the small guide pins.
    • Second, slide the bracket to the right as indicated in the second picture while lifting up. A small tab is holding the final bracket in place.
    • Remove the square metal bracket.
  12. Canon PowerShot SD850 IS LCD Screen Replacement: 12 단계, 이미지 1/1
    • At this point the screen should be easy to lift from the camera body.
  13. Canon PowerShot SD850 IS LCD Screen Replacement: 13 단계, 이미지 1/3 Canon PowerShot SD850 IS LCD Screen Replacement: 13 단계, 이미지 2/3 Canon PowerShot SD850 IS LCD Screen Replacement: 13 단계, 이미지 3/3
    • Lift the LCD screen and remove the two ribbon cables.
결론
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 2,529
