주요 콘텐츠로 건너뛰기
Canon PowerShot SD960 IS LCD Screen Replacement
필요한 것
  1. Canon PowerShot SD960 IS LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the camera over so that the bottom of the camera is facing up.
  2. Canon PowerShot SD960 IS LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
    • The battery door will open, allowing you to access the battery.
  3. Canon PowerShot SD960 IS LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Push the the orange battery lock back to release the battery.
    • Remove the battery.
  4. Canon PowerShot SD960 IS LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
    • Working on your electronic device while it is powered on can result in electric shock. Power off, unplug, and remove the battery of your device before continuing.
    • Close the battery door, and turn the camera over so that the bottom of the camera is facing up.
    • Using a PH000 screwdriver, remove the two 5.5mm screws.
  5. Canon PowerShot SD960 IS LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the camera over to the side
    • Remove the two 4mm PH000 screws from the side of the camera.
  6. Canon PowerShot SD960 IS LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Turn camera over to the data port side with the panel that reads A/V Out.
    • Lift open the latch that covers the camera's data ports.
    • Remove the one 2.4mm PH000 screw on the left.
    • Remove the one 4mm PH000 screw on the right.
  7. Canon PowerShot SD960 IS LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Turn the camera over so the lens is facing up.
    • Remove the front cover.
  8. Canon PowerShot SD960 IS LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Turn the camera over so that the screen is facing up.
    • Remove the back cover.
  9. Canon PowerShot SD960 IS LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Remove two 2.4mm PH000 screws from the plate on the front of camera.
    • Gently remove the plate.
  10. Canon PowerShot SD960 IS LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Turn the camera over to the data port side again.
    • After removing the front panel in the previous step, the AV/OUT panel should be free to remove. Gently slide out the A/V panel.
  11. Canon PowerShot SD960 IS LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Turn the camera over so the top panel that reads "Image Stabilizer" is facing up.
    • Remove the two 2.4mm PH000 screws from the top of the camera to the left of the power on/off switch.
    • Gently remove the panel from the side of the camera.
  12. Canon PowerShot SD960 IS LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Turn the camera over so the screen is facing up.
    • Remove one 3.2mm PH000 screw from the top of the LCD screen.
    • Remove one 3.2mm PH000 screw from the bottom of the LCD screen.
  13. Canon PowerShot SD960 IS LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    • When you remove the top panel it will remain attached by a small orange cable. You can leave the cable attached; it will not obstruct you from completing the following steps.
    • Gently remove the top panel.
  14. Canon PowerShot SD960 IS LCD Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Remove two 3.2mm PH000 screws on the side of the camera, to the right of the button that reads "Func. Set."
  15. Canon PowerShot SD960 IS LCD Screen Replacement: 15 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Use a nylon spudger to flip open the teeth holding the small, orange data cable in place.
    • Gently remove the small, orange data cable. The cable should now hang free.
  16. Canon PowerShot SD960 IS LCD Screen Replacement: 16 단계, 이미지 1개 중 1개
    • Once the data cable is removed, the panel to the right of the LCD screen with the button that reads "Func. Set" will be free to remove.
    • Gently remove the panel to the right of the LCD screen.
  17. Canon PowerShot SD960 IS LCD Screen Replacement: 17 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 17 단계, 이미지 2개 중 2개
    • Locate the large, yellow data cable by turning the camera over so the lens is facing up.
    • Find where the data cable connects on the front of the camera.
  18. Canon PowerShot SD960 IS LCD Screen Replacement: 18 단계, 이미지 2개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 18 단계, 이미지 2개 중 2개
    • Use a nylon spudger to flip open the teeth that are holding the large, yellow data cable in place.
    • Gently remove the data cable.
  19. Canon PowerShot SD960 IS LCD Screen Replacement: 19 단계, 이미지 3개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 19 단계, 이미지 3개 중 2개 Canon PowerShot SD960 IS LCD Screen Replacement: 19 단계, 이미지 3개 중 3개
    • Remove the LCD screen.
  20. Canon PowerShot SD960 IS LCD Screen Replacement: 20 단계, 이미지 3개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 20 단계, 이미지 3개 중 2개 Canon PowerShot SD960 IS LCD Screen Replacement: 20 단계, 이미지 3개 중 3개
    • To remove the casing around the LCD screen, begin by removing the top of the casing (which is in two pieces). First, remove the small hinge on the right side.
    • Then, remove the rest of the casing.
    • The top of the LCD screen casing should now be removed.
  21. Canon PowerShot SD960 IS LCD Screen Replacement: 21 단계, 이미지 3개 중 1개 Canon PowerShot SD960 IS LCD Screen Replacement: 21 단계, 이미지 3개 중 2개 Canon PowerShot SD960 IS LCD Screen Replacement: 21 단계, 이미지 3개 중 3개
    • Carefully slide out the LCD screen from the back part of the casing.
    • You should now have three components: The back of the LCD screen casing, the LCD screen, and the front of the LCD screen casing.
    • The LCD screen is now removed and can be replaced or set aside to access other camera components.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kacy Ewing
회원 가입일: 09/15/16
253 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 1,174
