소개
Disassemble the back cover in order to open the camera and access the inside components.
부품
부품은 필요하지 않습니다.
  1. Remove the double AA batteries before starting to disassemble. This will prevent you from permanently damaging your camera.
    • Remove the double AA batteries before starting to disassemble. This will prevent you from permanently damaging your camera.
    • Turn the camera to the side that has the screen. Unnscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
    • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
  2. Put the camera with the lens facing up, turn it to the side where the DC IN A/V OUT DIGITAL Cover and lanyard attachment are located.
    • Put the camera with the lens facing up, turn it to the side where the DC IN A/V OUT DIGITAL Cover and lanyard attachment are located.
    • Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
  3. Put the camera with the lens facing up, turn it to the side where the Cover battery is located. Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver. Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
    • Put the camera with the lens facing up, turn it to the side where the Cover battery is located.
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located. Unscrew the black 3.4 mm screws with a #00 Phillips screwdriver.
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  6. Put the camera with the lens facing down, turn it to the side where the DC IN A/V OUT DIGITAL Cover and the silver lanyard attachment are located.
    • Put the camera with the lens facing down, turn it to the side where the DC IN A/V OUT DIGITAL Cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  7. Turn the camera with the lens facing down. Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened. Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully make pressure downwards on the opening tool so the cover can gradually open.
    • Keep making pressure and slowly slide the opening tool through all the gap.
    • There is one point when the cover will disassemble completely.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  8. This is a final picture of how it's going to look when you disassemble the back cover.
    • This is a final picture of how it's going to look when you disassemble the back cover.
    • You will have 3 parts:
      • 1. The camera
      • 2. The DC IN A/V OUT DIGITAL Cover
      • 3. The back cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Maria
회원 가입일: 2014년 03월 13일
611 평판
안내서 1개 작성함
New Mexico State, Team 1-3, Easley Spring 2014 New Mexico State, Team 1-3, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G3
4 회원들
안내서 4개 작성하였습니다
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - 답글
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 1,080
