주요 콘텐츠로 건너뛰기
Canon PowerShot SX120 IS Back Cover Replacement
필요한 것
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: 2 단계, 이미지 1/1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX120 IS Back Cover Replacement: 3 단계, 이미지 2/2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Back Cover Replacement: 4 단계, 이미지 1/2 Canon PowerShot SX120 IS Back Cover Replacement: 4 단계, 이미지 2/2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: 5 단계, 이미지 1/1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: 6 단계, 이미지 1/3 Canon PowerShot SX120 IS Back Cover Replacement: 6 단계, 이미지 2/3 Canon PowerShot SX120 IS Back Cover Replacement: 6 단계, 이미지 3/3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: 7 단계, 이미지 1/1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Maria
회원 가입일: 03/13/14
875 평판
안내서 1개 작성함
New Mexico State, Team 1-3, Easley Spring 2014 New Mexico State, Team 1-3, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 25
전체 시간: 1,719
