주요 콘텐츠로 건너뛰기
Canon PowerShot SX120 IS Control Dial Replacement
필요한 것
  1. Canon PowerShot SX120 IS Control Dial Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Control Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Control Dial Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SX120 IS Control Dial Replacement: 3 단계, 이미지 2개 중 2개
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Control Dial Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot SX120 IS Control Dial Replacement: 4 단계, 이미지 2개 중 2개
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Control Dial Replacement: 5 단계, 이미지 1개 중 1개
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Control Dial Replacement: 6 단계, 이미지 3개 중 1개 Canon PowerShot SX120 IS Control Dial Replacement: 6 단계, 이미지 3개 중 2개 Canon PowerShot SX120 IS Control Dial Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Control Dial Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
  8. Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: 8 단계, 이미지 3개 중 1개 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: 8 단계, 이미지 3개 중 2개 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
    • Use a pair of tweezers to remove the old control dial and set the new control in the same place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Destiny Bretado
회원 가입일: 03/20/14
122 평판
안내서 1개를 작성함
New Mexico State, Team 1-3, Easley Spring 2014 New Mexico State, Team 1-3, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 1,695
