주요 콘텐츠로 건너뛰기
Canon PowerShot SX120 IS Function Buttons Replacement
필요한 것
  1. Canon PowerShot SX120 IS Function Buttons Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Function Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Function Buttons Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SX120 IS Function Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Function Buttons Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot SX120 IS Function Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Function Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Function Buttons Replacement: 6 단계, 이미지 3개 중 1개 Canon PowerShot SX120 IS Function Buttons Replacement: 6 단계, 이미지 3개 중 2개 Canon PowerShot SX120 IS Function Buttons Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Function Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
  8. Canon PowerShot SX120 IS Function Buttons Replacement, Control Dial: 8 단계, 이미지 3개 중 1개 Canon PowerShot SX120 IS Function Buttons Replacement, Control Dial: 8 단계, 이미지 3개 중 2개 Canon PowerShot SX120 IS Function Buttons Replacement, Control Dial: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
    • Use a pair of tweezers to remove the old control dial and set the new control in the same place.
  9. Canon PowerShot SX120 IS Function Buttons Replacement, Function/Display/Menu Buttons: 9 단계, 이미지 3개 중 1개 Canon PowerShot SX120 IS Function Buttons Replacement, Function/Display/Menu Buttons: 9 단계, 이미지 3개 중 2개 Canon PowerShot SX120 IS Function Buttons Replacement, Function/Display/Menu Buttons: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Once casing and control dial have been removed, you will begin removing silicone button pad.
    • Use tweezers to grip the edge of the silicone pad and begin lifting upward.
  10. Canon PowerShot SX120 IS Function Buttons Replacement: 10 단계, 이미지 3개 중 1개 Canon PowerShot SX120 IS Function Buttons Replacement: 10 단계, 이미지 3개 중 2개 Canon PowerShot SX120 IS Function Buttons Replacement: 10 단계, 이미지 3개 중 3개
    • Continue lifting until pad is separated completely from the camera.
  11. Canon PowerShot SX120 IS Function Buttons Replacement: 11 단계, 이미지 2개 중 1개 Canon PowerShot SX120 IS Function Buttons Replacement: 11 단계, 이미지 2개 중 2개
    • Once pad is separated from camera, use tweezers to grip button(s) that need to be removed, and lift until it has been separated completely from the pad.
결론
작성자
3다른 기여자 명과 함께
Brea Baca
회원 가입일: 03/20/14
101 평판
안내서 1개를 작성함
New Mexico State, Team 1-3, Easley Spring 2014 New Mexico State, Team 1-3, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 1,892
