주요 콘텐츠로 건너뛰기
Canon PowerShot SX160 IS Format Wheel Replacement
필요한 것
  1. Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: 1 단계, 이미지 1/2 Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: 1 단계, 이미지 2/2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
    • The screws are located directly above the LCD screen.
  2. Canon PowerShot SX160 IS Format Wheel Replacement: 2 단계, 이미지 1/2 Canon PowerShot SX160 IS Format Wheel Replacement: 2 단계, 이미지 2/2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the side of the camera.
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the bottom of the camera.
  3. Canon PowerShot SX160 IS Format Wheel Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX160 IS Format Wheel Replacement: 3 단계, 이미지 2/2
    • Use your hands to gently separate the back plate from the camera.
    • Slowly pull off the camera plate until it fully detaches from the camera.
  4. Canon PowerShot SX160 IS Format Wheel Replacement: 4 단계, 이미지 1/2 Canon PowerShot SX160 IS Format Wheel Replacement: 4 단계, 이미지 2/2
    • Use your hands to gently separate the front plate from the camera.
  5. Canon PowerShot SX160 IS Format Wheel Replacement: 5 단계, 이미지 1/1
    • Locate and replace the format wheel on the front panel of the camera.
결론
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
회원 가입일: 03/11/15
1,920 평판
안내서 6개 작성하였습니다
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015 회원
UCCS-PANKO-S15S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 621
