주요 콘텐츠로 건너뛰기
Canon PowerShot SX160 IS Function Wheel Replacement
필요한 것
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: 1 단계, 이미지 1/3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: 1 단계, 이미지 2/3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: 1 단계, 이미지 3/3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: 2 단계, 이미지 1/2 Canon PowerShot SX160 IS Function Wheel Replacement: 2 단계, 이미지 2/2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX160 IS Function Wheel Replacement: 3 단계, 이미지 2/2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: 4 단계, 이미지 1/1
    • Remove and replace the function wheel.
결론
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
회원 가입일: 03/11/15
1,920 평판
안내서 6개 작성하였습니다
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015 회원
UCCS-PANKO-S15S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 551
