주요 콘텐츠로 건너뛰기
Canon PowerShot SX160 IS LCD Replacement
필요한 것
  1. Canon PowerShot SX160 IS LCD Replacement, LCD: 1 단계, 이미지 1/3 Canon PowerShot SX160 IS LCD Replacement, LCD: 1 단계, 이미지 2/3 Canon PowerShot SX160 IS LCD Replacement, LCD: 1 단계, 이미지 3/3
    • Unscrew the 2-4.8mm black screws from the front of the camera using a #0 Phillips head screw driver.
    • Unscrew the 2-4.8mm black screws from the side of the camera using a #0 Phillips head screw driver.
    • Unscrew the 3-4.8mm black screws from the bottom of the camera using a #0 Phillips head screw driver.
  2. Canon PowerShot SX160 IS LCD Replacement: 2 단계, 이미지 1/2 Canon PowerShot SX160 IS LCD Replacement: 2 단계, 이미지 2/2
    • Use your hand to gently separate the back panel from the camera.
    • Continue to pull the panel until it becomes completely detached from the camera.
  3. Canon PowerShot SX160 IS LCD Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX160 IS LCD Replacement: 3 단계, 이미지 2/2
    • Unscrew the 3-3.75mm silver screws from the function wheel panel of the camera using a #0 Phillips head screw driver.
    • Remove the function wheel panel from the camera and set aside.
  4. Canon PowerShot SX160 IS LCD Replacement: 4 단계, 이미지 1/1
    • Unlatch the LCD ribbon connector from the camera by gently lifting up on the ribbon while pulling away from the camera.
    • Be extra cautious not to tear the ribbon.
  5. Canon PowerShot SX160 IS LCD Replacement: 5 단계, 이미지 1/1
    • Using your hand, pull the LCD screen away from the camera and replace.
결론
Congratulations, you have successfully replaced your LCD screen. To reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Jamie Secretan
회원 가입일: 03/11/15
1,920 평판
안내서 6개 작성하였습니다
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015 회원
UCCS-PANKO-S15S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,337
