주요 콘텐츠로 건너뛰기
Canon PowerShot SX160 IS Outer Case Replacement
필요한 것
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 1 단계, 이미지 1/3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 1 단계, 이미지 2/3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 1 단계, 이미지 3/3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: 2 단계, 이미지 1/2 Canon PowerShot SX160 IS Outer Case Replacement: 2 단계, 이미지 2/2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX160 IS Outer Case Replacement: 3 단계, 이미지 2/2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jamie Secretan
회원 가입일: 03/11/15
1,920 평판
안내서 6개 작성하였습니다
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015 회원
UCCS-PANKO-S15S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 1,752
