주요 콘텐츠로 건너뛰기
Canon PowerShot SX160 IS Shutter Button Replacement
필요한 것
  1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: 1 단계, 이미지 1/3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: 1 단계, 이미지 2/3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: 1 단계, 이미지 3/3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Shutter Button Replacement: 2 단계, 이미지 1/2 Canon PowerShot SX160 IS Shutter Button Replacement: 2 단계, 이미지 2/2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Shutter Button Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX160 IS Shutter Button Replacement: 3 단계, 이미지 2/2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
  4. Canon PowerShot SX160 IS Shutter Button Replacement: 4 단계, 이미지 1/1
    • Locate and replace the shutter button on the front panel of the camera.
결론
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Jamie Secretan
회원 가입일: 03/11/15
1,920 평판
안내서 6개 작성하였습니다
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015 회원
UCCS-PANKO-S15S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 2,679
