주요 콘텐츠로 건너뛰기
Canon PowerShot SX260 HS Battery Replacement
필요한 것
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: 1 단계, 이미지 1/1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: 2 단계, 이미지 1/2 Canon PowerShot SX260 HS Battery Replacement: 2 단계, 이미지 2/2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: 3 단계, 이미지 1/1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
결론
Tyler Kelch
회원 가입일: 03/05/15
622 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 11-8, Blackburne Winter 2015 Sam Houston State, Team 11-8, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G8
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 23
전체 시간: 1,078
