주요 콘텐츠로 건너뛰기
Canon PowerShot SX260 HS Flash Assembly Replacement
필요한 것
  1. Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 1/3 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 2/3 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 3/3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 screws on the left side.
    • Remove the 2 screws on the bottom of the camera.
    • Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Flash Assembly Replacement: 2 단계, 이미지 1/1
    • Use your plastic opening tool to gently lift and remove the back face plate.
  3. Canon PowerShot SX260 HS Flash Assembly Replacement: 3 단계, 이미지 1/1
    • After removing the exterior screws, use your fingers to gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Flash Assembly Replacement: 4 단계, 이미지 1/1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  5. Canon PowerShot SX260 HS Flash Assembly Replacement: 5 단계, 이미지 1/1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  6. Canon PowerShot SX260 HS Flash Assembly Replacement: 6 단계, 이미지 1/1
    • Next, you will need to remove the dial panel by removing the 2 (3mm) screws on the back side of the camera.
    • Gently remove the dial panel with your fingers.
  7. Canon PowerShot SX260 HS Flash Assembly Replacement: 7 단계, 이미지 1/2 Canon PowerShot SX260 HS Flash Assembly Replacement: 7 단계, 이미지 2/2
    • Remove 1 (3 mm) screw from the flash generator with a Phillips screw driver
    • Gently lift the flash generator off of the camera with the plastic opening tool .
  8. Canon PowerShot SX260 HS Flash Assembly Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Gently unplug the ribbon cable with your tweezers.
    • Be careful not to rip it.
  9. Canon PowerShot SX260 HS Flash Assembly Replacement: 9 단계, 이미지 1/2 Canon PowerShot SX260 HS Flash Assembly Replacement: 9 단계, 이미지 2/2
    • Using your plastic opening tool to gently move the plug lock from the end of the ribbon cord by lifting it upward.
    • Gently remove the ribbon cable from the connector with tweezers.
  10. Canon PowerShot SX260 HS Flash Assembly Replacement: 10 단계, 이미지 1/2 Canon PowerShot SX260 HS Flash Assembly Replacement: 10 단계, 이미지 2/2
    • Gently remove the ribbon cable assembly from the top of the camera with your tweezers.
    • This cable is a long piece that runs across the top of the camera.
    • The flash assembly is connected to this cable.
    • Once removed gently lift out of the camera
    • Replace the ribbon cable with the attached flash assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler Kelch
회원 가입일: 03/05/15
622 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 11-8, Blackburne Winter 2015 Sam Houston State, Team 11-8, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G8
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 22
전체 시간: 1,668
