소개
If you need to replace your LCD Screen on your Canon PowerShot SX260 HS this guide is for you!
필요한 것
The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
Remove the 2 (3 mm) screws on the left side
Remove the 2 (3 mm) screws on the bottom of the camera.
Remove the 2 (3 mm) screws on the right side of the camera.
다른 3명이 해당 안내서를 완성하였습니다.
